BUILD - RCD Longblock/Elite Single
WhiteMamba_Scorpion
Only too much fuel if the tuner doesn't know what he is doing.
It's amazing how much cleaner a truck runs with bigger injectors that are dialed back to closer to the factory IPW window is. Like stock only with way more power. Crisp is the word I believe.
I'd say 750 is capable with 15%. It's not the size or just how must they can make when strung out almost three times more than factory IPW... but more so, having and injector that can make that power much more efficiently without using tons of timing and IPW to inject the amount of fuel desired.
Sooooo.... you wanna tune my truck?
WhiteMamba_Scorpion
I forgot it's not yours anymore... technically Codys but you put it together. I'll call ya tomorrow if you have 5 mins.
Black AOD
Ohio
No means yes
Exactly! Listen to this man.
Acceptance is the first step in admitting you have a problem. A problem to saying No to a Wonderful Pro Mod 94 that longs for a new home in the White Mamba 6.7 Fender Well :ford:
Black AOD
Ohio
