jdgleason
Gearhead tunes and 71 or a 72mm atmosphere turbo. Best towing setup I've ever driven.
What about a trans cooler? Motor will live but you burn your trans and that's it? I believe a transmission cooler with electric fan and a mag tec pan will keep your trans happy
I don't find that stuff to really be a necessity. 6.4's come with a good size cooler from the factory. The deep pan being worth its money in temp drops is a debatable topic, IMO.
JD what gearhead tune specifically? I ran cooler towing in hot street than I currently am in street. But I'd like the trans to live as long as possible, so I turned it down. I'm running torque tows. Truck hates running between 55-63mph, temps climb between then cool off once I get it over 65.
My truck never comes out of race. Depending how heavy you tow will dictate the tune. I've pulled 10-11k with the cruise set at 85 and not touched 1,000* though. That was with the 72 and stock fuel.
Which is why I'd do an upgraded atmo. It's pretty inexpensive and IMO definitely worth it.
Sent from the Bayou
I agree with ^ but I would leave the lpfp alone unless u need the power doing a low pressure is just a non reliable mod IMO
Throw a good converter in there
