Fwiw the 4r100 in craigs at 80mph is at the same rpm as the 5r
first gear feels almost the sameThe last two gears are the same ratio. .71 in overdrive iirc.
Ill be curious to see how things work with a lower first gear. Might be better at the track tho
you have to buy a brand new converter they will not upgrade if you have a standardHow do you have a converter upgraded to an HD? I always figured you needed to just buy a new TC
Have you considered trying RCD's Ultimate Converter?
Travis-if you want a stock core, we might work something out as a trade for mine and some cash... lemme know if youre interested..
I am interested to see how MPDs turns out. I would like to but I daily drive it also, and 5 gears are better then 4 for daily driving. lol
So 4th gear in the 4r100 is at the same ratio as the 5R110s 5th?
