carli 2.5"spring question
WHY NOT
Carlyle IL
Yup works great, make sure you get some decent shocks like fox 2.0's will help keep it under control.
04cr450
harford county, maryland
Yes. I still added the two spacers. The 2.5" Icon coils do not correct the lean by themselves.
Also, I reread what I typed. My front is not higher than the rear. The rear is taller by 1/2"-1". I cant figure out how to edit my other post.
ok , bummer, i was hoping i could get away from using the pmf spacers(i have 3 of them on my drivers side to equal the passenger side).SMH, disappointed
04cr450
the ouo is a waste for me since i have the pmf spacers on hand. Only need 1/2", with these new springs and fox shocks i hope i see an improvement lol
JRLott
TX
I'm thinking the carli springs would ride nicer than stock however?
Oh hell yes! I used a spacer in my 05 5.4 with Bilstien shocks, and thought it was great. This time I used Carli springs and Bilstien shocks and it kicks the old trucks a$$ in the ride department. I can only imagine how good it would be with Fox or, better yet, Carli valved a Fox shocks.
dsmracing1
Alberta, Canada
Oh hell yes! I used a spacer in my 05 5.4 with Vilstien shocks, and thought it was great. This time I used Carli springs and Bilstien shocks and it kicks the old trucks a$$ in the ride department. I can only imagine how good it would be with Fox or, better yet, Carli valved a Fox shocks.
No doubt hey. Looking Forward to trying this out in the spring time! It's mostly an OCD thing with the leaning drivers side for me haha. If I can improve the ride quality at the same time it's a win win!
nowayout
Is the OUO Levelerset adjustable when it is installed on the truck? Or must you disassemble to adjust it?
WHY NOT
Carlyle IL
You need to take the pressure off the axle and springs but you can adjust it on the truck. Just not with the full weight of it on it.
Kxc
South Jersey
Are the Carli coil springs and the Deaver leafs the softest ride ? I never pull or haul anything other than a small 2000 lb boat. Just looking for the softest ride I guess.
JRLott
TX
Gotcha. I must have misunderstood your comment. Leaning is driving me crazy, but it's just not in the cards to fix right now.
JRLott
TX
From what I've read, yes. You'll get Carli/Icon depending on who you ask, but I've never seen a answer other than Deaver for the rear. I went with Carli, but don't think you can go wrong with either brand.
Ice Cream Sammich
I have Icon full leafs in my rear, no blocks. It rides absolutely better than stock. Running stock Ranchos right now too. Haven't hooked up the first trailer, but I'll report back.
JRLott
TX
Icon springs or Deaver? Thought I remembered reading they were Deaver, but that could quite possibly be a total fabrication of my mind.
Snayke
Grande Prairie, AB
Hows about that side pic? haha
So you're running the 5" Icon leaf pack in the back, no blocks. Also a 2.5" level up front correct?
04cr450
Ok well this thread got long and drawn out lol ordered my springs and fox shocks will report back with pics... it'll look the same as it does now just hopefully ride much better
WHY NOT
Carlyle IL
Im sure you can find a used set on one of the forums or CL for much cheaper than getting a set from ford.
