TANK'S 250
stock tire size ....................31.5"
stock gearing ......................3:73
stock tire weight..................51lbs(no wheel)
stock rpm's at 65mph in 4th gear...2,546
40" tire...............................40"
4:56 gearing.........................4:56
tire weight............................99lbs(no wheel)
rpms with new tire and gearing....2,490
so you would have LOWER rpms at 80 mph with 40" tires and 4:56 gears than a stock truck....
....4:56's....
I didn't know stock was 35"....where did this info come from?
but even if a stock tire was 35"(which I'd still like to see proof)....a 4:56 is still the best option by 50rpms...especially since you just added about 300lbs of rotational mass to your drivetrain(40" tires and wheels)
....and 300lbs in rotational mass is not the same as having 300lbs in the bed of your truck...rotational mass is completely different.
....4:56's....
