changing gears 3.55 to 4.10 2010 f250
TD-5
British Columbia Canada
After a gear change from say 3.55 to 4.10 or 4.30, is there a parameter in the ECM/PCM that needs updated so it recognizes the new final drive ratio. We can correct for tire size thru the H&S programmer or MCC but there is nothing for gearing.?
Jesse_01
Prince George, BC. Canada
I asked a few programmer's and they said no you don't have to reprogram anything.
Sent from my SM-N900W8 using Tapatalk
Martin #6
Truckee, CA.
3.55's to 4.10's
3:73 is the happy medium imo. you will run out of rpm with 4:10s and use a ton of fuel.
I'm thinking of doing this gear swap also. Looking at a gear ratio calculator I'd be at 1866 rpm's doing 65 mph with my 34" tires. Do you think these rpm's are too high for sustained hwy driving and towing a 12k 5th wheel? Also will this range of rpm's increase my chances of water pump cavitation that I should be concerned with?
negative on both fronts. do it.
drunk on diesel
if anybody wants to swap 3.55 axles for 3.73's, I'd love to do so. I put shorter tires on my reg cab and would like some more gear
as long as your coolant is good and you've got the updated degas setup, I wouldn't worry about cavitation
