RSK
I never had a vibration, but my truck was an F-250. My blocks were 1 7/8" compared to the 3 5/8" that your F-350 had. Your driveline changed a little more than mine did. My guess is you'll need a shorter single driveshaft or find a way to shim the 2 piece so that it will work, if that's even possible on a lowered truck.
Truck looks really good by the way!
Thanks, it's a work in progress! overall maybe putting an f250 block in the Rear and some new bolts in again might be the cheapest most cost effective route unless i can shim it enough to work. I think the carrier bearing needs to go up higher, the 1 piece driveshaft might be the ticket.
