I don't think slow crank, only no crank. Does your truck fire up currently? If you're sure the starters you are putting in are 100% healthy, and no motor resistance, then it's gotta be a wire that isn't allowing full juice to flow. If a wire is barely making a connection and you try loading it, it can heat up and deteriorate the terminal. Happened to me once and it was tough to find cuz it's not obvious to the visually. The connection will still allow you to measure voltage but won't flow enough current. This usually happens in high current wires, not control wires usually. Do you have the ability to run a new temporary wire from your battery to the Starter to make sure that connection is good?
I'm stumped, just trying to toss around ideas. I wanna know what it is...
