Cts exhaust back pressure
BIG JUICE
Valrico FLA
Can the cts pull the exhaust back pressure from factory sensor or do I need to install an edge one? Trying to get ready for that street max;)
redneck101
Does on a 7.3, but I don't know what pids are available for the 6.7.
Sent from my Nexus 6 using Tapatalk
dseitler
Royal Palm Beach, FL
I can tell you the way I do it. Edge EAS 12v Power Supply Kit comes with every thing you need even the correct sensor. Put a Hydraulic Tee Fitting in your EBP tube on your passenger side exhaust up pipe. Basically put Edge Sensor along with the factor sensor. There is a manual that comes with it that tells you how to load the custom sensors to your CTS. At that point you can add sensor all you want from axle temp to secondary cooling system temp if you want. I will post a picture of the tube setup later on.
HeavyAssault
Middle, VA
Edge Insight CTS users need to call tech support with their unit SN#. Then Edge will set that SN# for the new updates.
Otherwise the updates will only apply to the CTS2 models.
Sterling6.7
Ok, dumb question of the hour. Now that I can, what does monitoring the exhaust back pressure do for me? Thanks in advance
