WHY NOT
LOL LOL
Sent from my I fone 5
They are so excited by the fact that they think they've caught big foot that they forget to inspect the truck
I got the Warhammer tuner in mine with full deletes. Truck suppose to have 400 Hp + 200 RWHP for tuner, less bigger tires, etc. So I figure around 500. Going to try an take it to the track this summer or dyno it and see what it does.
Well ford put a new turbo on my truck and now the turbo wines louder then before and it's still fluttering now wtf do I do??? Will deleting and tunnin fix this
What "fluttering" are you referring to? The bouncing of the boost needle, between 18 and 22 or so?
Well kinda the turbo flutters when in 6th gear driven around 50 mph or so at low rpm when you let of the go pedal a little bit. Dealer now tells me this is normal and is caused by the egr
Real unique name, Zach. Lol
Sally didn't send this
I think its fine mine does the exact same thing putting around my neighbor hood in 6th gear and then performs flawlessly crushing at 80 or mashing on it.
Next time your in 6th and at 50 or below just click the button on the shifter and lock out 6th. These things love to stay in 6th even at 35-40mph.
Sent while dismantling your neighbors meth lab.
Mine used to flutter but only in cruise control around 62mph. Is it doing it when you are using the pedal as well? Maybe take a short video for us to see exactly what it is doing.
Possibly the wastegate needs adjusting ?
These things are only 400 flywheel from factory unfortunately. I've never seen a tuned truck make more than 530. So given your 40s your probably closer to the 450-480 imo
