Deranged rebuild, the next chapter
Dalpilot
Austin, TX
Good deal Matt, looks weird sitting somewhere else. Remember, she will test you like nothing else. Good luck man.
Bustedknuckles
Ive been following it since day one on Compd, been nothing but one epic fail after another..... Good luck!
Countryboy07
N. Manchester, IN
Good Luck on the new Build! Are you going to change the engine set up at all? or are you going to just try to get it running and make a full pass with it's current set up? Can't wait to see what you can do with it! Glad to see it is staying a diesel and that it will be rebuilt, there has been a ton of time and money put into that thing already and it sure would have been a shame to see it go to someone that wouldn't have kept it diesel.
-French
Cutting-Edge Diesel
Newkirk, OK
-French
changing it up a bit. :thumbsup:
didnt get started as soon as I wanted, had to gather and work our replacement heifers. But started this afternoon and only got to the heads. one of the head gaskets were blown, Oil plug has metal shavings on it (expected) but what wasn't expected was this......
Only contacted on #4
