HeavyAssault
Okay tell me the good, the bad and the ugly. Keep it simple and to the point. I'm looking at getting one and want to be sure it's up to snuff for our trucks. Videos are cool of your ride in action.
The Detroit trutrac is a limited slip. I am not sure what you are looking for exactly. I also do not know what you are putting this in.
you will never hear or feel it engage/disengage. Its not a true locker and uses a clutch system to work.
I guess I do not understand what you are looking for then; you have it all figured outOkay I left out a few details. I understand the concepts of traction devices. Current application would be a 2006 F350. The subject is the Detroit TrueTrac. Pretty simple....stay along those lines.
Pop quiz...Its a gear driven traction unit. What is a Detroit TrueTac??
Read up:
The Detroit Truetrac was the first helical gear differential ever introduced into the automotive aftermarket as an Eaton brand. It remains the leading helical gear-type limited slip differential in the industry. Detroit Truetrac's proven helical gear design eliminates the need for wearable parts, resulting in maintenance free traction recognized not only for its toughness, but its smooth and quiet operation as well.
http://www.eaton.com/Eaton/Products...veAftermarket/Differentials/PCT_221471#tabs-2
Additional questions you can start your own post.
I do not know if you are trying to be a prick or not but I appreciate you setting me straight. My bad, my statement was a little off. I must have been thinking of another limited slip.
I retracted all my info as you already have it all figured out and obviously did not even need this thread. Depending on needs, LS is a waste of money; you're better off with a Detroit locker.
Apparently now that Detroit and eaton are one in the same, things have changed a little over the years.
Best of luck
A Detroit and a trutrac are not the same.......Detroit is a gear locker. The truetrac is a soft locker that uses helical gears to lock both wheels together. They do not operate on any of the same principal. The trutrac uses helical gears and friction to lock both sides together. The trutrac is for the most part smooth. The Detroit is clanky and very rough but robust.
You can't even compare the stock LS to a TrueTrac.
:whs: and way strongerYou can't even compare the stock LS to a TrueTrac.
Correct. The trutrac is much closer to a full locker than a limited slip.
from a dd to a full competition truck, a detroit trutrac is hard to beat for all around use!!
Is this in reference to me? if not, please disregard below
If so, I have already stated that I have used the Detroit truetrac and Detroit locker, and I currently have the stock limited slip.
The Detroit truetrac may be a bit better than the stock ls, but its still a limited slip unit and has serious limitations.
This isn't even about me, this is not my thread.
