Disadvantages of Bigger Wheels ??
Charles
If the sidewall doesn't form an angle as it rolls in toward the wheel bead, what on earth do people suppose will provide lateral control to keep the tire centered on the wheel?
If the sidewall is straight, it would be like strapping a vehicle down to a trailer with the straps all running straight vertically from trailer to the attachment point on the vehicle.
You don't run straps like that for the same reason that you want your sidewalls to actually have some diagonal angle to them. That is unless you like to feel the truck squirm around as the wheels rock back and forth inside the tires with the straight sidewalls flopping to one side, then the other trying to stabilize the side-loading forces during a turn.
TARM
First off here is an actual buggy power stroke 7.3 now this is a rare one:
YouTube Video
ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
YouTube Video
Excursion running Super duty Icon 6" springs (works out to a 8" lift on a Excursion). Running 44" Boggers BW cut out flares. This is no mall crawler.
But hard off-roading with big heavy trucks does break crap without a doubt. LOL
YouTube Video
YouTube Video
YouTube Video
YouTube Video
YouTube Video
STROKIN N STYLE
GOM via NC
I've watched a lot of videos on that excursion. That dude is not scared to bounce it off a tree if that means getting out. His Jeep recovery videos are good too
sent from somewhere in the country
