oneturboforme
- Joined
- Sep 12, 2011
- Messages
- 1,040
- Reaction score
- 0
if you are good at fiberglassing you should give it a try its quite easy..... basically what i did was, take a peice of cardboard and trace the minimax onto it, cut it out then i hot glued it into the position i wanted which was slightly angled toward the driver.. then start fiberglassing work slow and try to get it the best you can with fiberglass, sanding it should be done asap so the fiberglass inst all the way cured or its gonna take you awhile.. then fill the little voids with glazing filler.. sand smooth and paint... heres some pics of mine.. sorry for the crazy paint job.. i like it but to each his own...
