Drag Run
Sniper32
Stafford, VA
Heres my time sheet
60 ft ----------- 1.906
330 ft ---------- 5.685
1/8 ET --------- 8.942
1/8 MPH ------- 75.25
1/4 ET --------- 14.24
1/4 MPH ------- 92.23
fordfreak4life
doug keeps telling me that mine will run 13's with his race tune if i can get it down to 8k lbs which wouldn't be hard
MorganY
college station, tx
not bad #'s.
btw...i read your other thread about your dyno. I used a calculator and it spit out 409 hp at the wheels (assuming 8000 lbs) which is probably a whole lot closer to what you're putting down. as they say...the track never lies. now put some injectors in and let it rip
this is true, my setup before 190s gave me 434RWHP spraying a 50/50 mixture of meth and got me a 13.99 on the track
Silverback
Heres my time sheet
You still have a small margin for growth. A 13.99 is possible but you gotta get the perfect launch
EDIT: For the record i pull 1.7 60's easily and its a smooth take off. I launch at 20 psi. Hell i could build even more boost if i wanted to but then things get squirrelly off the line so there's no point. And I've never had a problem with the truck pushing through the brakes, yet I hear about guys having that issue
BlueWaffle
Grapevine, TX
i push through my brakes at anything over 15 psi :mad:
Sniper32
Stafford, VA
Stock injectors and turbo
Silverback- like i said if i try to launch at anything over 12psi i get a lot of front end hop...is there a way to fix that or is it just an issue with oversized off road tires?
SIX_OHH
I meant stroke of luck....whats injectors/turbo. My brakes feel like they could hold 190s
Silverback
I can practically stand on the throttle and it won't push through the breaks...maybe my larger tires and weight helps? Hard to say, maybe you have a pad/rotor issue or even an issue with the hydraulics?
SIX_OHH
Stroke of luck fix your brakes lol. Topic at hand. How can we launch harded?
Silverback
I'm running 37" MTs and 22s so that can't be it, what rpm are you leaving the line at?
SIX_OHH
285 75 16...what psi? Been running 55 cause i had no idea what is best. Strap the fron end? Like the axles and frame duramax style? How bout the rear till i get traction bars?
Cutting-Edge Diesel
Newkirk, OK
I ran 40 in the front and 35 in the rear. I dont know whats best I havent played around with it much. I haven't tried it but some people put a ratchet strap over the frame and the front control arm and suck it down.
Sniper32
Stafford, VA
2100 RPM gives me about 12psi and a smooth launch...anything higher and im hoping.
Guess my next time ill have to try straping the front end and droping the tire psi bcs i pretty sure its still around 60
Sniper32
Stafford, VA
OK yall as you know Im a newb at drags...i understand the concept of strapping the front end down, but how exactly do you strap it? do you run a ratchet strap from the leaf springs to the frame on both sides?
SIX_OHH
Frame to axles?
