Draining fuel cell(yeah, I know I made a legitimate post, crazy)
SevenThree
Aggieland,TX
Kid that works for me put about 1/2 gallon of gasoline in my '16(tank 1/2 full), truck was NOT started, thank God. What is the best way to drain the fuel cell?
Ps- Hi guys!đź‘‹
Jake
TEXAS
Some small, like 1/4 vynil tubing, fill it with diesel before you fish it into the tank, with the end that it staying out capped. That should be enough to get a siphon going without sucking on it. Should be able to drain down to 1/2" in the tank. Fill it back full and be good to go
Sent from my XT1650 using Tapatalk
Jake
TEXAS
Good luck with it! Are you training on your own now?
Jake
TEXAS
Cool! Reiners to police dogs, that's an interesting turn! Been busy here, my brood geldings ate just turned out getting fatter. Too many irons in the fire, haven't shown in two years.
Jake
TEXAS
Water hose will get most of it, it will be easier to get in the tank also, smaller hose will just be able to leave less behind. The solution for pollution is dilution!
bluedge8
Champlin MN
I'd consider dropping the tank with what is at stake, or at the very least siphon out, fill and siphon again.
Vader's Fury
Chesapeake City, MD
Are the new trucks that sensitive to fuel?
I would think with only a 1/2 gallon of gas being added to the tank that if you just fill it up and go you would be fine.
That should dilute out the gas enough that it really shouldn't matter.
I know I have done that with other older trucks before but nothing newer than a 6.0.
8WR_ZJ
Artic diesel fuel has up to 15 percent gasoline mixed into it. Along with other stuff...
08Monster
That's what I was thinking. Seems excessive.
Sent from my Moto Z (2) using Tapatalk
Petro
Lincoln Nebraska
Agreed. I used to run 2 or more gallons of gas through my 6.4's per tank when it would drop below 0° here to prevent gelling. Never has any issues. I'd fill it with diesel and go about your way.
ckrueg
Belding MI
Probably also a good idea to put in some fuel additive to increase the lubrication.
SevenThree
Aggieland,TX
I'm going to drop the tank to be safe if someone could walk me though it, excessive is probably right but I am overkill. He was suppose to fill the def too and although he says he put it in the right rez, I am worried now so I'm going to drop the tank.
Jake
TEXAS
Yeah fuel system is expensive,
I haven't dropped the tank in that truck specifically. But I bet they're all similar. Should be a couple straps holding the tank up. Support the tank, stacking up a bunch of blocks will do the trick. Loosen straps, lower tank just enough to unplug fuel sender, unhook fuel lines, filler neck, and vent line. Then you can just keep pulling blocks out till you have it low enough to get it out from the truck.
My buddies girlfriend put about a half tank of gas in his truck, we drained it empty, put 10 gallons of diesel back in, drained it, then filled it back full of diesel.
Draining down to a gallon should leave about 0.025 gallons of gas, fill back with 35 gallons of diesel puts you at 0.07% gas, which there is probably more than that at the pump when they swapped what product was in what transport trailer.
