Dual Fuel Pump Wiring
Tree Trimmer
you didnt say you had alift pump. that bein the case, you would just use two stockers, like in that pic, without the rest of the stuff. out of your lift pump into whatever line you need to get to the pumps, into a Y block, into the pumps, out to a Y block, into the line to get to the motor.
i can only base this next part off a 7.3, but it should apply to your 6.0
make sure you are not using the stock feed line, oversize to accomodate the extra pump. on ours, its -10an hose from tank to pumps, and -8an from pumps to motor, into a Y, to -6an to the heads. you guys use much smaller injectors than we do, so your sizes might be different.
