lincolnlocker
Looks like the only thing messed up after clearing the codes is the 1211 code. Do what 6.0tech said and start there.
live life full throttle
Oil pressure on the HPOP reservoir is 35 psi at idle.. brought the rpm's to 2,000 while parked and it dropped to 28 psi
Yep.. oil might do that too. I have seen that happen with rotella, mobil, and motorcraft 15-40 oils.Sounds like your lpop isn’t giving enough pressure. You should see higher then 25psi I would imagine
Yep for sure. Supposedly though, as long as voltage never drops below 12.5 volts, it shouldnt affect it.. but i know for a fact that when my dually drops below 14v it starts running like chit! Jimdawg185 can vouch for that too.. id get another alternator on there and see what happens when it stays around 14.2v..Also, battery voltage running should be 14+ volts
Still mine ***erThe dually you “use” to have
