Cdaley403
Has anyone experienced an instant E4OD failure? I now have nothing but reverse. It happened when I was using 4Hi for the first time and had the truck in D just on a gravel road. Acted like it popped into neutral and since then only reverse. I pulled the dipstick multiple times after running it since and clean perfect level fluid is what it reads. I also pulled the test port plug out of the trans and got the same fluid look.
I was wondering if I had transfer case issues because someone told me they claim to have had a tcase only work in reverse before and it was the issue. I pulled the tcase fill plug and got nearly a quart of extra fluid? Kinda weird but everything in the tcase looked fine. Help me out I’m leaning towards transmission rebuild but what’s next to confirm that.
120k miles 97 7.3 F-250 HD 4x4
Thanks!
Thanks!
