motoxracer42
- Joined
- May 21, 2011
- Messages
- 553
- Reaction score
- 0
Are you going to need to use a new map sensor?? I often wondered fi you would have to "tweek" that to run significantly higher boost levels.
truck is going to command full fuel at 30psi so i would imagine i would be wasting money buying a new map sensor. i probably should replace it as its seen over 120psi in the past lol. if i change to a different map sensor like a 7 bar (highest made) i would have to have the programing rescaled to match.
