7.3 will not benefit from a ficm. Stock or upgraded.
LOL
If the oil cap blows off when running, stop spending money on the motor. You are having huge compression issues. The only way pressure gets into the crankcase is by "blowing by" the rings. Hence the term BLOWBY.
But seriously I was thinking a upgraded IDM from swamps or somewhere else I am going with gearhead tuning.
http://swampsdiesel.com/prestashop/...e-high-frequency-injection-driver-module.html
I would get the UVCH and other wiring issues squared away before you start replacing big stuff like PCM/IDM etc. ESPECIALLY if you have corrosion going on.
Wrecking yard.
Okay borrowed a tester from a buddy, results from the pass side as follows had zero issues on the drivers side all 415 after 5 full cycles.
#1 410, #3 415, #5 415, #7 415
Running test #8 450 and #1 445 ish the rest where around 450
I think I may have a cracked injector cup or two.
Still lacking power till upper rpm, speedos off 5mph and knock is still present while cold on #5.
So I am thinking fuel filters in the tank are clogged and maybe IPR/ICP issues need more testing injectors have "haze" @ cold start over two days of sitting or below 60*. Another thought is weak fuel pressure and bad idm the other thought is fuel pump is worn.
Last thing I can build 2600-2700 icp @ 40% duty then it basically drops off a cliff automatically says no more pressure.
Boost tubes?? Wtf would you do that? And are you talking about 400/800 injectors, or 400hp/800tq? I didn't know they made 400/800's, if they did, I would imagine a 4088 would be a tad on the small side, if you are talking power wise...160/30's and a 38r, and leave out all the other stupid bullsht.
I'm well aware there is bigger Tyronius, 800% nozzle is straight off the ballin chart doe. Even if it was 400/400's or 400/600's, I think a 4088 is going to need a friend or two to help it out. I could be wrong. I'm just trollin' so don't mind me tho.
