Ezlynk shows us a sneak peak.
bigrpowr
<How I Fly
Administrator
I do not know that they will go to the extent of MCC when it comes to end user tuning capabilities. Realistically, anyone can tune on virtually any open source platform (SCT, Bully Dog, etc) though. You would just need to invest in the time and software.
EZ Lynk is still very new, so I am sure we will see a lot of features added as time goes on. Jody (our tuner) has been working with them every day and they have a lot of ideas for the future of this thing. Should be a game changer.
Yes, that is what we figured. But it has no priority right now. I am curious to see how far they will expand this thing.
tell jody i say hello.
Hottrod81
With the EZ Lynk, it looks like every one is running about the same power. Is PPEI establishing the engine parameters and the tuners are just putting their spin on the trans shifting?
Justin@DP-Tuner
No. A lot of people are just offering it with the tunes PPEI has for it. There is no limit or boundaries for the power that can be had in regards to tuning. The tunes we offer for it are similar in power figures, but will be different than the PPEI tunes. We can offer higher power tunes, but since our tunes are *** ON, we don't go crazy in the HP department for reliability and longevity purposes.
jcain
A couple different ones, but spartin is the only one I can publicly name
Ikyo
Does anyone know right off if the factory pyrometer still works on the ******d tunes and the No Limit blockoff plates?
08twinturbo
Well it's new enough that most of my dealers have no explanation of what all it does. I keep getting the "buy one and try it". But I too would like to know more about the adjustability feature for the end user like speedo, etc. These are all questions I get asked and havnt got definite answers what all will be available. A single load non adjustable tune is tough for most.
c63 AMG
Installed my ****** with Ezlynk today having trouble staying connected with iPhone. Tunes still work just can't connect to Ezlynk.
bigrpowr
<How I Fly
Administrator
you have to have 4G or wifi capability .
c63 AMG
Yes I know and I do. Ive actually had the Ezlynk plugged in for a few days and it's worked fine up until today when I did the ******. It connected fine to flash and for that drive it was ok. Next time I took the truck out it wouldn't connect and has stayed that way.
If I disconnect Ezlnk from my obd port will I need to reflash again? Think I saw somewhere when you disconnect it returns to stock.
Justin@DP-Tuner
Issue like this came up on another forum today. Are you anywhere near a saved Wifi signal already on your phone? The guy was having issues like you explain, but he was in his driveway. The phone was jumping between his home Wifi and the EZ Lynk.
Just a thought.
c63 AMG
Just a thought.
Thanks saw his posts that's not my problem. My phone says it's connected to Ezlynk wifi but when I open the app it doesn't connect. Tried many times while driving and in different locations with the same result each time. It worked fine until I actually flashed the car then On the next restart this started.
Justin@DP-Tuner
Hmm, that is strange. Not sure what would have caused it to lose communication. You may want to get in touch with EZ Lynk about that. Sounds like something may be up with the App or the hardware itself.
c63 AMG
When you go to Wifi settings, can you see the EZLYNK still?
Yes phone says I'm connected to Ezlynk wifi every time but the app doesn't say so. Received an email from Ezlynk they said to unplug then plug back in and should be good to go. Hoping this is just a fluke and not a regular occurrence.
Ikyo
You can try forgetting the EXLYNK access point and see if that helps too. Another option is to enable Airplane mode, kill the app, disable airplane mode and try to reconnect.
