03-Blue-Powerstroke
I have an FICM that does the same thing. It will show 48 volts all day but, the truck does not run right with it. When I switch to my spare it works. Both have the same flash as well.
its a reminder for morons who think they are gassers dont start them until it stops... those with early strategies that buzz after you turn the truck off are for the hangover crowd..
Why I ask is because the buzzing tone has changed lately
if the buzzing sound/tone has changed when you key on to cycle the glow plugs before you crank on it....it pretty much means the spool valves are sticking really bad. If that is what yours sounds like...i would hafta bet that your truck starts rough and has a rough idle when cold...right?
He was talking about the buzzing when you Key on...not off. When you key on, it's the spool valves cycling...which is normal. However, there was a earlier ford flash which cycled the injectors when the truck was turned off to splash oil out of the tops of the injectors...i had this flash at one point.
if you don't drive the truck in the winter...then this would be a good time to pull the injectors and send them to Jesse and have him go through them. Maybe even make them 190's
I started the truck today the buzzing sounds weak, started the truck let it warm up smoking grey blueish smoke burns my eyes.. drove the truck for 25 mins or so and shut it off and the buzzing sounds way stronger. Also when you first start the truck when cold the battery light comes on is that normal? I have brand new batteries and the proper ones this time.
Syn. Valvoline the oil in the truck has 4100 miles on it. I have two bottles of rev x here I will probly change the oil this week.What type of oil are you running in your truck.?
I know I haven't tested anything but I'm kinda leaning toward injector stiction is the problem.Try that before you go buying a new FICM.
