front end upgrade
amarillo250
Montreal, Quebec
OK, I'm looking to upgrade my front end and need some info on what to go for.
The Truck is a 2006 F250 and has a 2inch leveling kit(Rancho springs)
I like to get rit of all the balljoints and ad a precision dual steering stabilizer.
What else do I need ???? :shrug:
fordfreak4life
how are you going to get rid of the ball joints? kind of a crucial part of your steering system
Sent while spinning 18 wheels
fordfreak4life
Looking to replace them with heim joints and hope to find track bar and steering bar with heim joints
that's not even legal in the us except for on off road untagged trail rigs, only place I know stuff like that is used
SouthFlstrokin'
what? dude, really take the time to type and more people will help you. Your broken english is worse then the haitian guys i work with.
Zmann
you may not need an adjustable trac bar unless your axle is off center ?
Your draglink will only need replaced if the ball joints are bad on the bar ?
and the factory one is adjustable so IDK what other type your looking at ?
if you decide to go Heim on anything make sure they are double shear
but at the end of the day you will still have at least 4 ball joints in the knuckles unless you swap to a King pin axle LOL
search topgun customz for nice dual stabilizer options
and PMF or precision metal fabrication for trac bar and other component options
as far as balljoints look at XRF
the pic is a jeep, the components are the same except the upper and lower arms are a single "Radius arm " on ours
