dentexpowerstroke
I always wondered about why it negative arched. What do the w codes come on usually?
V codes will lift aprox 2", X codes aprox 3.5"
Actually gonna lower my truck. Since I have Shackles and hangers on the front just go throw stock springs and still have 3.5 lift and stockers in the rear.
So do a set of U code springs up front, and how about rears ? P & Y with auxilary spring
My truck says "V" codes up front. I guess that's why I seem to sit higher than onthers i've seen. Now how do I tell which springs are in the rear and do the different springs make the rear sit higher just like the fronts?
SD's
X codes won't ride much stiffer than a V code and will ride better than any lift spring.
S — 2C34-5310-AAB, 4,000 lb.
T — 2C34-5310-ABB, 4,400 lb.
U — 2C34-5310-ACB, 4,800 lb.
V — 2C34-5310-ADB, 5,200 lb.
W — 2C34-5310-AEA, 5,600 lb.
X — 2C34-5310-AFA, 6,000 lb.
What kind of lift would i have if i put the x codes on the front and c codes on the rear of my 02?
From your mothers room Trebek
