Front Spring Codes
Copracr
C codes are about 4 inch lift for an excursion, about 2 when they were on my early 99 f250 IIRC
NEVRNF
NW IL
Seems that joe Myers ford are a buncha jews
You do realize that those ARE NOT FACTORY springs. They are aftermarket version of the Ford spring quite possibly made overseas. I'm not saying thay are bad, Just that you cant compare price.
OSCS
Houston, TX
Never even looked at the link, I assumed it was another dealership. I buy my ford parts from sunrise now.. They have killer deals
bad12jr
The x codes on mine have a slight maybe 3/4" to 1" positive rake. I think 350 blocks would level it nicely. Thatll be a spring project though.
Sent from my NookColor using Tapatalk 2
OSCS
Houston, TX
I have xcodes and 350 blocks it sits perfectly level! I'm actually trying to take it down to stock springs in the front though. My questions is what block if any is needed to level the rear out with stock v codes up font?
bad12jr
I think 250 blocks would be pretty close on a stock spring truck. Buddy's 250 set pretty close to level on a stock set of springs. I might be interested in trading. It you want measure them and see if there is a height difference.
Sent from my x2 somewhere
OSCS
Houston, TX
How old are or springs? I'm almost positive the will be positive rake. The xcodes put you up 2.5-3" over vcodes. What is the difference in 250/350 blocks?
OSCS
Houston, TX
I misunderstood the trade. Anyways my front middle of hub to bottom of fender well measure 27" front and 27" rear.. It's almost dead even
Tree Trimmer
e99 f250, with x codes in front, with stock 250 blocks in back, will sit level
this is what my truck has. and the x codes make it ride so much better.
and they only lifted mine 2", not 2.5 or 3
OSCS
Houston, TX
I guess every truck is different. I noticed a dramatic decrease in ride quality when I switched from v to x codes and my truck sits perfectly level with 350 blocks
