Jeff@Spartan
I just use the heat blanket material from napa to make them. Then use the existing studs on the intake and pump cover to hold it down. You probably would be ok with no covers. But with how much radiant heat is under the hood on these trucks I like to keep the lines and pump covered.
Hey Mike.....do you know the exact name or part # for this stuff? I went to NAPA and O'Reilly's today, and neither place had it in stock or even knew what I was looking for.
