HS-MotorsportsZane
- Joined
- Aug 8, 2013
- Messages
- 469
- Reaction score
- 0
Tuning does make a huge difference....... as has been mentioned![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Intercooler won't do anything besides drop IAT some. It's more efficient but not to the point where it will make a big difference on spool up.
If the lag really is that bad make sure you check all connections intake and exhaust side for any leaks.
Not sure what you mean by obsolete? If you like the tune then there's no reason to switch. If every thing checks out good and you have smoke control issues you can have a little fuel pulled down low, but that isn't going to help spool up unless the truck is choking on fuel.
it is noticeable actually. more so on the trucks that need it worse. have you run with and without one ? mostly what i noticed was throttle response.
Which 64mm turbo ? Bell or sxe ? If bell, sport or spool housing ?
Switching to a larger compressor and turbine is counter productive for the problem you're having. You need tuning adjustments.Bell spool housing. I think after talking with some people I might switch to a 366sxe with a divided pedestal and plan to throw more fuel shortly there after
I understand that just haven't really been impressed with the charger for what it was supposed to do. And I have tried gear head tunes as well. I just figured that if I'm going to add some fuel here soon might as well go a little bigger shilr there's a good deal. I'm still deciding on it but last time I talked to Midwest they said they did some really nice tuning on yours. You're running the same kit correct?
I did my own tuning on my last truck, which had the bell turbo H&s kit. Morgan @ midwest wrote me a tune for it and I tried it but ultimately I always used my own tuning. Geared was the first tuning I tried with my H&s kit and was eventually why I purchased the McC unlock and started doing my own.I understand that just haven't really been impressed with the charger for what it was supposed to do. And I have tried gear head tunes as well. I just figured that if I'm going to add some fuel here soon might as well go a little bigger shilr there's a good deal. I'm still deciding on it but last time I talked to Midwest they said they did some really nice tuning on yours. You're running the same kit correct?
It's always the turbo's fault......
It is the tuning. I have the same turbo...I did one mod and my truck did the same thing, it would not spool until 2500. Had my tuner make some changes and it was back to normal.
Thanks
