harrisford
- Joined
- Dec 28, 2012
- Messages
- 50
- Reaction score
- 0
Everyone always says that about the 500hp mark. Maybe a little more air is all your engine needs to push it over 500...
oem is good enough till 500hp ish. so why change it?
The few times I have had to pull and reinstall my factory kit, is enough reason to replace it. That giant filter housing in the middle of it is a pain. I chunked part of it across the garage the first time I had to reinstall it.
If you leave the filter completely assembled its a breeze to install and remove. All you have to do is unhook the coolant hose coming from the degas bottle to the radiator, unhook at the degas bottle. Pull out the filter minder, unhook maf connector and loosen the hose clamp right after the hard plastic casing. Give it a little wiggle and it will pop right out.
I remove usually atleast 3 a week and I NEVER disassemble it
4 steps to pull an air filter is 3 to many, with my setup it is as follows
1) remove air filter
Sent from in a ditch up side down and on fire with the wheels still spinning
Obviously I wasn't referring to someone with an aftermarket system or encouraging the factory system for that matter. I was offering tips for those above complaining about how bad it sucks to remove.
Either a) you have check engine lights on
Or b) you forgot the mention removing the filter minder and maf connector before your step #1 Lol
mine is almost done. just waiting on the silcon coupler from the turbo. will be 5" polished aluminum all the way to a big AFE filter. very soon.
I used 4" and an AFE dry-flo filter, works great, you get quite a bit of intake noise, but everything on my truck is loud, so it blends right in
Didn't you incorporate pieces of the factory intake as well? Use a 45* bend? Or 30*?
I'm not into tig welding. Who sells a big badass polished intake? Pics?
