Figured I start a thread about trying to figure out problems
I put my homemade Gen3 together, and since then, truck idles fine, but when I give it some RPMs, acts like a miss, or something is wrong.
I did hook it up to a scanner, said ICP failed. So I replaced the ICP sensor, no change. Replaced pigtail for it and the IPR. The IPR pigtail was bare, also replaced it.
All the sensors share a wire that is gray with red stripe. Is that wire suppose to be grounded? Because mine is. Maybe the IPR could be stuck somehow? I don't think I have any bare wires. Haven't had a chance to put back on scanner yet.
One crazy thing is that when I unplug the oil temp sensor, it can make t run smoother. Then another time, I pulled the plug on that sensor and engine died. Weird.
