Homemade Gen3 electric problems
Magnum PD
VA
It not exactly like I can ask swamps for help, I put it together so not their problem.
It does require refinement of the tuning files...
But it sounds to me like you need some ipr work.
Magnum PD
VA
One thing that is happening, long crank, then possible stall. Hope I don't have bad LPOP. Only got a few thousand miles on it.
Magnum PD
VA
I actually did that. Around 20psi. But tech book says more is normal. Wonder if I should take pressure from port at oil filter.
Magnum PD
VA
Took passenger side VC off, 4 has almost no oil coming from injector spout, 6 and 8 not much. 2 is the only one that has noticable oil coming from it.
Still takes a least 10 seconds before it builds pressure to try to start.
Magnum PD
VA
I went ahead and pulled injectors, replaced o-rings, replaced the seals in the Haldex pump, and reinstalled everything.
Still doing the same thing. Don't know what to do now.
Magnum PD
VA
I'm gonna make sure oil is coming from all the oil spouts in the daylight tomorrow but, why is it throwing a code and defaulting to 725psi when there is plenty of HPO?
Magnum PD
VA
Is the signal return wire coming off the ICP suppose to be gounded? Might be my problem. I do have another wiring harness coming.
How do you like that turbo? Before you started messjng with the hpo system ;)
Magnum PD
VA
Don't have much to compare to be honest. Boost and back pressure are pretty equal.
