Injector o-rings?
Rusty
If oil isn't coming out/filling up the hpo Rez, you need to check the lpop. Then pickup tube.
No it isn't filling up.
If the top set of injector O-rings fail, oil will leak out around the base of the injectors (and possibly enough to not let pressure build). You can remove the valvecovers and crank it to see if there is oil leaking around the bases. Cheers!Wouldn't there be engine oil in the fuel bowl if it was injector o-rings? I checked the fuel bowl yesterday and the fuel was its normal color
Again...... LPOP
I would also check your injection pressure regulator. Get a rebuild kit from international or Riffraff Diesel. Or Ford although the last time checked they were $120.00 versus $25.00 at IH. Also check the harness that goes to the IPR as it sometimes will deteriorate from Diesel and oil causing the signal to short, also check the plug.
I'd do this before doing a L pressure oil pump and iirc you don't have to pull the block to replace the LPOP.
j
