How many miles on your 6.4?
Newark, DE
mines up to 149k right now, looking at oil cooler replacement in the near future might as well do the valve train while im at it. other than that no problems except for the radiator at 13x,xxx
Stroked777
Casper, Wyoming
Bought at 53k 04/12 and deleted 50 miles later, now it's up to 89k , did all the engine work at 78k in April, stock trans still holding on
skobiak
Alberta, Canada
08' with 93000 KM (57700 mi) Intake, tune, full exhausts, DP. Bought it 3 years ago with 63000 km. Few minor fixes (washer jets, front axle seal, broken seatbelt clasp in the rear). Other than that regular oil and fuel filter changes. Still running like a boss.......
slow poke
Michigan
Just over 190,000 miles on my 08. I run a mild H&S XRT Pro tune with a 5" exhaust and a drop in air filter. Truck has a small lift and 285/20" BFG AT tires and still gets 16 mpg city and 18 mpg highway. I kinda baby it but did have 4500+ lbs of bricks in the bed over the weekend. Rear bump stops were hitting even, I need rear air bags......
Emery19
Mount Laurel, NJ
just rolled 99k yesterday. bone stock. done few wear parts, like brakes and other things, oasis had a few things like blend door actuators and sensors in the exhaust when i bought it at 77k in 2011. have an h&s on the way, it needs tires and the radiator is leaking.
7.3powerstroke00
Brownwood
Knocking on 90k pretty hard now, racked up a few miles moving to stephenville, tx! But they should slow down a bit now that I only have to drive a couple miles to work now!
Powerstroke586
Eden, Utah
162K deleted since 15k running spartan 275 tune and occasionally 310 tune. Put a trans in. Did studs at 115k, had a lifter go bad at 130k (took out my cam). Multiple cracked up pipes. New HTT tow power turbos at 155k. Been a good oilfield work truck so far
extreme3807
Bucyrus, OH
Bought the truck around 45,000 miles in '09. Have 79K on it now. 19,000 miles at 600 HP, 10,000 miles at 1,000 HP, and 5,000 miles at 1,300 HP on a stock bottom end, no issues whatsoever lol
WILD_PHIL
East TX
Flirting with 103k. Miles have slown down on the truck since we got the TDI.
Learning about TDI's.
