How many miles on your 6.4?
WILD_PHIL
East TX
105,571 as off now. Really keeping the miles off of it now that we have a TDI Passat in the stable.
Stroked777
Casper, Wyoming
Bought mine in 04/12 with 53k, deleted and tuned a tank full later, just rolled 100k yesterday. studs, cam, full egr deleted and valve train upgraded at 75k, stocks trans still holding...
michigan37
248k haven't driven it in a month. Bounced it off a guard rail when I hit some ice. Should be done soon.
ckrueg
Belding MI
2010 with 284k. I bought it in October and it already had a full exhaust and egr delete. No problems so far. Michigan37, I just did the same thing last month.
Sent from my XT907 using Tapatalk
stroker96
Central OH
My "new" truck has 205k miles and runs great. Has had a dpf delete and spartan tuning since about 170k. Will have gearhead tunes and a egr delete within the next couple weeks
a_moore
Blowing in the wind
201,000
del @ 100K
before del two cab-offs. 1. leak up-pipe 2. high pressure fuel pump
after del not one problem.
At least 30% of miles towing 20,000lbs through the mountains. Actually more surprised at the 5R100....first auto I have got more than 100K on. No signs of failure. Knock on wood!
08stroker350
Bought my 2008 at 92,000km all stock. Real main seal went in the mountains at 105,000km. Parked it for about 10 hours as I went snowboarding. Warmed her up and drove the piss out of it for 2 hours all the way home. Was fixed under warranty... Did DPF delete at 120,000 and have not had any issues yet!!
146,000 right now...
TLH
Jacksonville Fl
I have 111, 000 on mine. Under warranty I have had 3 radiators, 1 dpf probe, egr cooler leaks, oil cooler, hydroboost, all 3 radiator hoses.
I now have a tuner, full race exhaust, cac tube, afe stage 2 intake, Magteh deep tranny pan, billit caps for the fuel and oil filters old ones cracked. Sinister coolant filtration system. 4" lift factory 20"rims with Toyo 35" mt's. My egt's stay around high 5's to low 6's even with me flooring it and pulling heavy I never crack 1, 000 for egt's. Once I get the egr bull**** off it will run even better.
TLH
Jacksonville Fl
All in all I love my 08 Ford F-250 Super Duty FX-4 Super Crew. Its always in build mode sometimes though it goes into a holdin pattern. But I will never get rid of it.
7.3powerstroke00
Brownwood
62000, had #3 injector took a dump few thousand miles ago... Got replaced under warranty... Other then that still rockin along good!
forcefed6.4ford
Medicine Hat... Again
120,000miles. Tuned for 100,000miles. Never been inside of the shop other than electrical problems with my back up sensors. Worked every day and tows heavy during the summer. Adore my 6.4.
zpi28
Mine hit 170K yesterday. Just put the SCT on today. It had the radiator done at 30K miles.
Stroked777
Casper, Wyoming
What was the issue they found? Mine work for 2 second when backing up then the system shuts off
RSK
Connecticut
A little update on mine. Its been deleted for 9,000 miles i'm at 99,000 miles no limit intake, mbrp exhaust, still in gear heads hot street tune. Trans temp sensor went, cost 14 from ford but the valve body had to be dropped to change it. It needed radiator hoses right after i bought it. Trans was inpspected when my mechanic was in there to change the sensor and he saw no metal shavings and very little to no clutch material. And the fluid looked fine.
