is the speed sensor located on the trans?
its in the rear end
Nitrous won't get you a whole lot if you don't have the fuel to go with it. A little over 500 hp is about all you can get with the fuel from stock injectors.When was this and did you have any FICM tuning? I would thin Nitrous would put you way over 500 with that setup.
its in the rear end
Is innovative good or did I waste my money because I did my research and they do most of the ppl in the diesel magazines
I made 436hp sotck injectors running 5" turbo back, S&B intake, no limit cold side and gearhead srlx... Hoping to have php ficm this spring And a mad hybrid turbo. Wanna see how much the stock injectors will do
I was leanin to stage 2 MTW and 175s but I think I'm goin to go hybrid route and stock injectors as well with PHP tuned FICM as well
That set up using a MTW stage 2, 175/100 injectors, airdog 150, a 58 volt FICM with PHP's atlas 80 tune and Innovative's extreme race dynoed at 548hp at our event this passed Saturday.
