smokedout, whose tuning? and what size tires you running?
Laid down 530hp on a dyno. Had 13.6 @ 7740lbs with an exhaust. Never got a chance to run it at the track with all the leaks fixed and a full fuel system.
Mods, 175/0 powermax riff raff billet wheel, adp rr, a1000,
Sent from my iPhone using Tapatalk - now Free
Nice work. For the price of stock nozzle injectors and the power you can get its hard to beat. How does the truck run with those injectors and no ficm tuning?
I had my truck dynoed this weekend,
My truck is a 05 F250 ext cab shortbed with studs, gaskets, egr delete, 6.4 banjos, blue spring mod, ccv mod, all updates, new oil cooler, coolant filtration, afe metal driverside intercooler pipe, air raid intake, 4" silverline dual exhaust, 35x12.5x18 tires, and a SCT innovative Xtreme Street tune. It put down a best torque of 652.62 and a best hp of 351.59 this Saturday and it was 55 degrees out. I was pretty happy with the numbers but I expected a little bit higher numbers after reading some of the similar set ups and numbers in this post. Still not bad though.
Just my thoughts, but I'd have expected 80-100 more RWHP and 100-200 more lbs-ft as well as long as the truck was in good running condition.
Sent while driving, drinking coffee and threatening to kill people in traffic.
Yea sorry about saying it's stacked. Because I'm not using it at all.But literary it is stacked because It will only work if I put the SCT on first on stock module . Then unplug the stock one and plug in the edge mod. After the sct is downloaded. I know the correct meaning just I've had people or mechanics still say you shouldn't do that. That it's unsafe. Even tho it's not stacking.
