How's every ones 6.4 stock tranny holdin up?
Pretty sure they are. I may be wrong.. I'll let someone else confirm.
Sent from my DROID RAZR using Tapatalk
to my knowledge the only difference is the pan shape, torque converter, and possibly filter setup depending on age. also, some of the later 6.4's had a 5 pinion planetary. in the main, the internals are identical.
RSK
Connecticut
If they are the same, in general, then idk why the 6.4s hold so much better while making gobs more HP and torque
probably because the 6.4's don't hit as hard. the 6.0's being a single turbo, hit harder. 6.4's having compounds pull harder, but are smoother, imo. That would be my guess. less lag, easier on the trans.
i tend to disagree, torque is harder on transmissions and 6.4's make a bunch more a bunch sooner. that being said i don't have an answer as to why they last as well as they do. probably tuning has a part to play in it.
MINK
London,OH
bingo...the torque is harder on them in general
forcefed6.4ford
Medicine Hat... Again
Tows heavy during the summer and tow 7klbs year round. Tuned since 21k miles. Currently have 116k miles. Never comes off of GH street. Never skipped a beat. All stock except turbos and air up grades.
swinky
Eastern, Nc
More lag is easy. Cuts wayyy down on tq
Sent from my SM-T210R using Tapatalk
I don't own a 6.4 but my understanding a couple years ago was that the trans was living longer in the 6l than in the 6.4 and the tcm was directly to blame. Has that changed? People were carrying on about how trannys in 6l were taking abuse in modded trucks for long durations.
swinky
Eastern, Nc
I had a brand new trans put in my 2003 6.0 and when tuned I could feel slip in 5th (direct clutch) it's always hated any type of downshift to 5th while under power. My trans only lasted 3 weeks at around 575hp and I'd guess around 900tq. After doing some reading I blame the factory 2003 TCM flash 100% my truck is on small tires and is around 7400lbs. There's definitely a big improvement on the 6.4 package when it comes to transmissions.
I haven't heard anything good about 03 &04 6l trucks. Under the hood or otherwise. I was referring to 05-07s and should have said that.
swinky
Eastern, Nc
I'm saying the 6.4 tcm flash is probably better than even the 05-07 6.0 flash
3brorce
My 03 6.0 treated me just fine. Trans, motor, never really had an issue and she was around 500hp.
trans is the same
i'm thinking yes. i also dont know if the TC characteristics have anything to do with it
johnp115
Southern MD/Charlotte NC
Mine did the same too but we are also talking a whole different ball game. Tuned + a batmo I'm pushing a little over 600 and 1200 lbs of tq so 500/900 doesn't really compare to that.
3brorce
I understand that as my 6.4 is north of both those numbers.
