How's every ones 6.4 stock tranny holdin up?
Heavyhaul
Wyoming
Looking to put my 71 on in the next month or so, and yes, I think that will be the end of mine too! LOL
Idk bud. I think the 4:30 gears help alot to reduce the load.
Tow X turbos and heavy loads. Still going strong. Although I did change my fluid at 65,000 lol. 125,000 on it now.
Rivets are the new duct tape.
WoodBoy
Alabama
mine has 63000 on it and has been tuned ince 27000. been to pulls many times, drag race daily, run the snot out of on the road, pulled 18000lbs on 275 tune from spartan. has ported rails, airdog, afe intake, 4" exhaust, no limit cold side pipe. truck has been run fairly hard and held up like a charm oh seen several 4800rpm launchs
4800?
78f100
Bonifay FL
Bought mine with 76-77k tuned at about 78-80k, now has 116k. Ran KEM 345 the whole time. I did studs and 71mm turbo, 60hp nozzles at 112K, I dd on the 345 and race on xrace since build. My stocker is still hanging in there with close to 40 drag strip passes, and lots of street launches all on 35's.
I also have pmf bars since 92k maybe that has helped.
Mike@MPD
Pasadena,MD
Damn I must have had a damn lemon trans you guys out lasted mime by like 60+k lol
Sent by my Nexus powered by this (╯°□°)╯
FordPSD64
San Antonio, TX
Bought mine with 81000. Been spartan tuned since the week I bought it. Has 104000 now. Still on the stock tranny. Been to the track a few times and done a few dynos. I drive the piss outta mine. Feels like clutches are starting to go on me though.
Frank_C
Orlando/Jupiter, FL
128,000 mi on mine, and still holding strong. Tuned via Innovative since ~87k mi. Run Ex Race 80% of the time, Ex Street the other 20%. I use Race lock trans tuning on both files.
Those 41k miles tuned have not been easy, At least 30 passes(probably about 5 when I had 37's, 15 on my current 35's, and 10 on street tires) on the track, a few street launches while loaded with passengers, a couple dyno days, an scca rallycross event, 2 ~100-150yd long pedal to the floor burn outs, and plenty of offroad abuse. I can't believe it's still alive, and strong at that. Have had PMF traction bars for around 10k miles now, which I would say helped a bit.
one2nine
Altoona, Pa
47k on my '10 right now with about 11,000 tuned. I'm going to say 25 track runs and 5 pulls on it all with 35's. Did find some shavings on the pan magnet when I replaced the filter and added a ported solenoid. TC numbers are starting to creep up on me around 15-20 at full lock so a tranny will be coming my way in the spring. I'm sure I'd be fine for quite sometime, but with a few more power adder goodies planned in a few months it'll be peace of mind if anything.
Morkable
My son bought my 2010, and he has started to have some problems as of recent. It has a afe, dpf delete, egr delete and SCT with Eric's tunes. It is now sometimes not shifting into OD under hard exceleration. And occasionally it seems to lock into a higher gear when he goes to take off. (Lots of smoke and no power)
Do you think that the upgraded solenoid would fix this?
