FrankTheTank
what make and model do these pumps come in?
want to sell me that pump since u want to try something else??? haha..... im serious....
Possibly, let me play with my new design and if I come up with a kit maybe end up selling them.
Any updates on what pumps to try since the Sag pump is obsolete?
How did u make your custom line? Buy two hoses and have a hose shop piece them together?
I guess I am not clear, so where you able to get your truck up and running? I am sorry that there was a difference in those Hydroboost units. I sure never anticipated that. I did come across a piece online that they have different "ratios" so that might also play into your pedal feel.
The first conversion I ever did was about 12 years ago and with a 99 up booster.
To use a 99 up booster on. 97 down you need to first cut 1.5" off the pushrod. The mount/ flange to bolt it up to firewall needs to be fabricated. You need to use a 99 up ms, but need to add a portioning valve to rear line. I always just put an adjustable unit on. The front oem brake line connects, it's the rear line that is different.
Nice thing about 99-04 ms is that the bore is larger than the f superduty, it's 1 3/8 vs the old being 1 5/16.
If you used a 99 up booster, you could use a 05 up ms and have even bigger bore. In 05 they upped it to 1 1/2. Anything helps.
And this was the other thing on the rear port.
