I need your help on my build fellas....
02POWERSTROKE7.3
Alexandria, IN
Might of found a set of good heads. Is it bad to install heads from another block to avoiding wait time on a machinist?
Wont hurt anything as long as they are machined properly. No different then buying a new set of heads to replace a set that are cracked.
Sent from my SCH-I605 using Tapatalk 2
loboost
Depends on how good the good is. If theyve been milled true and pressure checked them use them otherwise you're likely going to do the job again within a few months.
Here the machine shop turns the heads over in 1-2 days tops.
If you can guarantee they're true and not cracked then yes otherwise no
06-sixoh
Bakersfield
If i can get em at a good price, i will have em milled ahead of time. Whats a good price on a used "good" set?
loboost
I've got a set I'm asking 700 for...but ive seen unknown used heads go for 5-800 a pair. Milled and checked 1000-1800
06-sixoh
Bakersfield
Hey all, im doing some injector research, and came accross holderdown's injectors. They are at a good price, would save me quite a bit over ordering from warren. What have you fellas heard about holderdown's injectors? Search isnt helping much.
So far, i am looking at about $6900 for turbo, supporting mods and injectors. Pff. Adding up quick. Im wondering if im up to it now. Lol.
06-sixoh
Bakersfield
But even with core charge they are a but cheaper. I will check again. I aent them an email as well. Thanks
Derkperk
Twin cities
I run RCD's injectors and have been very happy. I sent my set in w/55k on them and haven't had an issue for the 10k they have been in te truck.
06-sixoh
Bakersfield
Lol, just checked rcd... Prices arent exactly what i remember. Lol.
Been considering elites's DIY injector kits. How hard is it to rebuild the injectors at home?
Derkperk
Twin cities
Really?! I haven't looked in quite awhile but guessing they bumped prices as their products have gotten much better. I remember hearing guys having a lot of issues a while back. Other than a shipping mix up, I've had nothing but good experiences with them. Jared is the man!
bretferd
Cape Coral, fl
RCD seems to be the cheapest if you send your injectors in. They modify your injectors not someone's core. If you look under customer injector modification on RCD's injector page.
suprdzlduty
Prospect, Oh
I know that rcd that has issues in the past...everybody in this industry has been on a learning curve. I've talked to Jared and he is on the up and up. He'll take of you. I've received nothing but top quality products and service from RCD.
