neverkickn
Sounds like tuning to me, or tire pressure. Hard to tell for sure, but if you air up your tires and the problem persists, then you should consider looking at tuning.
Here's a looong interesting read on the issue, but they seem to be talking about bigger nozzles than our puny 30-80%'s.
http://powerstrokearmy.com/forums/archive/index.php/t-16543.html
As a ICP sensor gets old truck idle quality gets worse, especially coming back down to idle. Fuel pressure makes a huge difference as well. My truck became much smoother after I rebuilt my fuel bowl FRP, replaced fuel line fuel sleeves, as a final measure I bought dieselorings.com Aluminum FRP block & springs. I installed the gold spring for 62-67 psi.
Gearhead tunes seem to be choppy as a whole.
Gearhead tunes are far from choppy on the many trucks I've heard running them. In my opinion as far as any tuner is concerned, it isn't an easy task getting the idle quality and overall performance spot on the first time you pull the chip out of the mailbox. Not to mention, and its been said time and time again, no two of these trucks seem to run exactly the same even with the same mods.
Here is my idle with P.I.S. 230/100's...
http://www.youtube.com/watch?v=QYHIxLUSBkE
I'll get a nice idle video of the wifes Excursion this weekend if you like, she has 160/0 or "AC" injectors...
whose tunes?
I have the same issue with my truck....PIS 175/80 injectors, Honey Badger Jr and the rest is in the sig. Truck starts up smooth cold then once warmed up, has the loop/romp at idle. Does the same with Matt's (Gearhead) and Jonathan's (NLTD) tunes.
Waiting on Jonathan to come up to the Northeast for some live tuning.
Billy T.
[email protected]
Billy
Have you looked at oil areation on the dipstick to see if there's a corelation? I've concluded it's not oil temp related on my truck, but areation. I'm not certain if it's LPOP or HPOP generated...but that's my two cents.
