78f100
Correct Drake, it will not fire till it sees 500 psi. I have had 1 with a bad lpop with the same issues. It sure sounds like a hpop leak or weak pump. I could crank mine on gold brake clean it would run fine till shut down. Try to restart and nothing. The lpop was so weak it wasn't pumping enough oil while cranking over.
