First time I used it, it made a huge difference. After that it is just maintenance, you only notice the difference if you don't do it.
Drain fuel bowl, replace filter, fill bowl with seafoam. Replace lid on bowl, pour the rest of the can in the tank. Bust off the motor. Most of the seafoam will end up in the tank. Most of the cleaning will happen within the first fifteen seconds or so. But it will continue to work until that tank is gone. I actually notice slightly less performance and fuel mileage during that tank. But it comes right back on the next tank. I also try to remember to add a quart of two stroke oil to each tank of fuel. Keeps the injectors happy.
I thought seafoam was no good? Atleast thats what i recall reading but i i guess i read wrong, its worth a shot. I put some lucas cleaner in and she dont like it at all. Sputterin at low rpm and smoking to all hell at idle then next light shes brand new. Gonna top the tank off tomorrow to thin it out. Then ill try the seafoam.
I use Sea Foam when replacing the fuel filter also. Lucas is decent stuff, but its cleaning abilities are no where near Sea Foam. It is more of a lubricant than a cleaner.
I use the Power Stroke Diesel Cetane Booster every tank also...
Pretty much any of the cleaners mentioned here will work. If you put it in and didn't notice any difference, it just means your injectors are clean.
The first time I used it on my truck, I could tell the difference very quickly. After that, I can't tell when I use it at all. I keep using it just to keep it that way.
