12stroker
Yeah it does suck. And I do see in why your wanting to cut your losses. But if you have other transportation drive it and sell this truck and save up and get somthing in better shape.
Oh I completely get that. Its just that this thing has given me nothing but ****fits from day 1. Brand new water pump is leaking bad now. More time to pull it and hope that the o ring gasket is shot for some reason. If its the water pump for some odd reason thats another 220 just in parts I realllllly can't spend...
Just went out and looked for ****s and gigs. Didn't leak nearly as much as it did the first time it went bad so I'm thinking for some odd reason the gasket didn't seal properly. Well, hoping it didnt. New one is gonna be here when I get out of work...
Did you replace the stamped thermostat housing on the top of the pump? You can't reuse the old one. I tried and failed and had a massive leak.
helicoil.......
helicoil.......
Zac I have a right Angle drill and torque wrench if you need ... Heli coil isn't bad to do and deed the right way to fix it
Sent from my SGH-M919 using Xparent Green Tapatalk 2
