KC stage 2r Dual Ball Bearing VGT Turbo
Chatham036
How about a stock injector truck that is only used for towing?
Yes, the KC stage 2r will work great for you in that application. The PowerMax was originally the "go to" turbo for additional air flow and cooler EGTs while towing. With this turbo spooling quicker than a P max, you would be great to use this for a full time tow pig
Merc82
I just ordered one of these. Picked up an Odawg S3r manifold a month ago as well. Can't wait to get them both on my truck!
slvr bullet
Bumping this up. Can anyone share new info on how this turbo is working out? My MTW stage two has been good to me but I think it's time to retire it. I have fresh 190/75's from Warren diesel.
KCTurbos
We are hoping for the Stage 2r's to be available mid-late May. We have some being tested right now with the new bearings. Pending those results will determine the final release date.
PSD POWER007
Columbus, GA
What’s the reliability between a thrust bearing and ball bearing set up? I’ve had both and never an issue with a thrust bearing set up.
