Does anybody know what the widest tire i can run front and rear (either proxes or 420's) that will not rub on a lowered truck. no rear block and 5.4s, and what different offsets to have the outside of the tire to be the same width across the axle. I want the tires to be strait if you're looking down the side of the truck. its a 4x4 regular cab if that matters. Also to make the back tire as wide as possible i think a staggered set would look good. Prefer 20's or 22'
Does what i wrote make sence or should i reword it?
