Troika's Setup:
This one looks like it would fit nicely in the chasis of a DD. You might even be able to keep ac if you got more creative with charger placement.
What is the oil rail plumbed up for on the hypermax setup?
First time I've seen Troika's setup, what is the truck used for? Cool to be able to the accessories on one.
Just a thought about the pricing of one of these setups. Call Schieds or Hasley and see how much a turnkey nasty 2.6 5.9 cummins is, may be surprised by what you find out.
Professionally built and engine dyno'd 2.6 engine with pump and turbo: $45,000 (Dyno'd on an engine dyno to the 1100-1150hp area)
Stupid question, where is all of the cost wrapped up in a conversion? My naive self am looking at this thinking that any guy with access to heavy equipment/ class 8 parts and a machine shop could make this happen fairly reasonably......Where is the flaw in my logic?
Usage and goals probably. Sure you could take the first 8 cylinder injection pump you find and install a timing belt drive on the front of the engine, pop some 8.3 injectors in the holes, and make some lines and fire it up - but then the spray pattern might be wrong, the pump is only so so for making real power if even that, the timing belt drive is finicky and possibly unreliable, etc....
Front cover and gearsets are about $5Kish. Injection pump is $5Kish, injectors are a couple K, it all just adds up in a hurry. It should be noted that I don't think any of the mechanical trucks that are currently running or have ever run were ever at the track with anything less than 1Khp.
The Hmax setup pictured above (that is their kit and all the contents) is listed for $18K. You need a motor to hold that power built on top of that.... see how quickly it adds up? Machine time and engineering time are spendy things.
I see where you are coming from for the standpoint of a high HP build, I guess I am looking at it for lets say a 550-600hp build, slap an IP on time it via belt or chain and pop some 8.3 injectors in..... put a little bit of time into the 3-axis mill and a little bit more time into tuning. I am looking at the $:HP ratio compared to upgraded HPOP, custom tunes, HEUI injectors, Etc......
Now if you want the cool factor I would say go for it. I'm all for cool factors.
You gotta also remember Hypermax is very proud of their stuff... But then again they can make HP, especially when it comes to red tractors..
