you could very easily have a harness/connector problem where the connection opens up as heat is introduced. Ohm out the #2 injector harness to the FICM & check for loose/ spread pin sockets on the harness. I don't think a whole new harness is all that expensive, especially in comparison to what you've spent. It might be worth it at this point to just put a new harness on, especially considering all the other components you've validated.
