ingrahams
running the samd as Mike with no issues
Hey mike hows the temps during the winter? I would assume there is a thermistat inline somewhere.
What's the suggested retail price on these.
Not to many updates. All hot pipes are wrapped, all engine wiring is complete, hot pipes hopefully have no more leaks. Used a high temp coating on one side and a metal/graphite type gasket on one side. Moved hitch forward in the truck. Got suspension stops. Put new alradco radiator in. New degas tank is in. Moved hood shock over so the hood now closes without having to remove the shock. Also got a new tune from Eric. Didn't drive it hardly anymore as it was work work work.
Coolant tank tacked up.
I did. Thanks Robert. Unfortunately summit did not deliver. I tried intercepting the package with no luck. It will be here today though.
Detroit true trac is going in as well.
Just curious. Any reason you went tru trac instead of a locker?
I drive the truck a lot. Lotta guys out there with power run them so I opted that route.
It was my call, I told him to. LOL
