SEABEE08FX4
You could always run an upgraded pump and if you need more add a stock one.
That's what I was thinking either warren dual pumps or diesel site single pump. I like the single pump because it's simple. And the stock pump has held good pressure but I want to see what these injectors will do at there full potential.
I've actually got both. LOL
Fwiw, we've used the RCD thumper 2 with 255 conventional and it does very well. We've used the stage one but they are maxed at around 190-205 area. Had some not hold with 205's. I try and keep one of each on the shelf at all times.
Just throwing options out there.
Isn't the thumper II only for 05+?
Some 04 trucks have late style pumps.Isn't the thumper II only for 05+?
I would do the thumper but I have the old style pump.
the smoke @WOT is from the boost leak. and dual pumps are a good option, or one of these drop in pumps on the market. those being hybrids, im surprised
Fix that leak first and try it!
Unfortunately lol makes the icp sensor a real bitch to get to.Yes agreed. It's the early system
Are you planning on making anymore passes this year?
No sir, im done for this year & prolly the first part of next year. Im tired of breaking stuff for the time being. Trucks de tuned for now.....
Next big thing I hope to do with the truck is go to DPC next year.. but that's a lonnnnnnnnnnng shot with It being a 6.0.
If you were planning on having it apart in the near future I would start gathering parts to convert it. Blowing the stc fittings on the rails is a b*tch.
I hear ya. Have you ran it in the 1/4?
